I have a 1200 square foot second floor apartment that is presently heated using a forced hot water radiator system. The system is called a Paloma "Paloma Pak" heating system. It is basically a tankless hot water heater that they used back in the 1980s to heat apartments. With today's technology, can I replace it with a standard tankless hot water heater for similar results? My biggest problem is I can't find anyone to service the unit. It has an 85% efficiency rating when I check, so I can get no assistance to pay for the replacement. I think the tankless hot water heater may be an option.
Just get a combi if you need both DHW and heating or just an 'only heating' boiler. Few brands names: Immergas, Baxi, Buderus, Bosch, Riello, Junkers.
If you get I condensing unit I suggest you to keep the flow below 55°C, to exploit the condensing capability of the unit.
DHW units usually aren't suitable for space heating because those units lack a feedback control on water temperature (they assume inlet is standard 'acquaduct' range: 5°-20°, so returning with hot water may cause serious issues bringing water to boil in the exchanger leading to steam production and eventual explosion)
Seconded that tankless HWHs aren't appropriate for space heat -- I would use a straight boiler with an indirect tank instead of a "combi" boiler/tankless unit, though. Jan 12, 2019 at 0:19
Combi are not a 'plain' DHW Water heaters, those have a 'primary' boiler circuit that heats water that can go directly to radiators or can be diverted to a 'plate heat exchanger' that heats DHW water as it flows trough it. Also exists 'heat-only' versions that lacks plate exchanger and 3-way valve, so are 'regular' wall mounted boilers that can be used to heat an external water tank as well radiator's water.– DDSJan 12, 2019 at 13:31
Any names of wall mounted boilers as this is what the Paloma Pak does Jan 12, 2019 at 17:13
I do not think that a standard tankless water heater would work for space heating. A standard hot water heater does not have the feedback controls to keep a room at a specified temperature based on a thermostat.
A standard tankless water heater just delivers water at a temperature specified by its internal controls. It does have an internal feedback to deliver water of a certain temperature for a range of flow rates depending on demand, but I don't see how a room thermostat would control it.
A hydronic heating system pumps water around in a loop, but a standard tankless heater is designed for a single pass--it takes in cold water from the cold water supply and sends out hot water which goes to the drain after use.
There are tankless heaters whose output goes to a storage tank and presumably get recirculated water from the tank, but I don't think even this type is suitable for space heating. However, you should research this further.
See this: tankless water heater to heat home
1I agree the other part of the problem most tankless units I have installed only heat to ~130f. It would probably cost much more in the long run, a boiler heats the water in the loop so it uses a much smaller heating element for electric, and the gas models ease a large amount of heat up the vent stack.– Ed BealJan 11, 2019 at 22:24
