First off, I wear many Hats (jack of many, master of...some) I refer to the 2017 NEC often and able to answer my questions most of the time. This one bounces my brain too much. Providing this answer takes a deep knowledge of the NEC gained by years in the trade (or a book geek) therefore I humbly and respectfully thank you for sharing your knowledge.
I'm in Colorado, USA. ( Machavity) (my fluke* says 122v... so 244 volts (Harper)?:)
The heater is a CADET (cadetheat.com Vancouver, Washington) Its tested to UL standards. They cover their a** on installation by saying
- *1. All electrical work and materials must comply with the National Electric Code (NEC), the Occupational Safety and Health Act (OSHA), and all state and local codes, without giving specifics other than...
- The maximum amperage load you can put on one circuit breaker is limited to either 80% of the circuit breaker capacity, or the maximum amperage rating of the thermostat, whichever is lower. & some other reference regarding breaker being ...20% larger than load(or something to that effect, not quoted)
I'm installing 4 baseboard heaters of different sizes, each in a separate room, each on a separate breaker, with the smallest being a 240/208 Volt, 500/375 watts, 2.1/1.8 amp, with a wall mount thermostat (mechanical double pole 120/208/240 volts, 22 amps).
My Question is, If I run 12-2 wire with a 15 amp breaker that has only the one above mentioned heater, am I within NEC? My concern is if the breaker is too large to protect the appliance.
Take this one step farther...240-V baseboard heater, 2.1 amp draw, 10-2 wire with a 30 A breaker total run length 40 ft. Can you "overprotect" or defeat the breakers ability to trip/disconnect by having too small of a load?
