The context is a set of outdoor stairs.
Are there any clever techniques to minimize flickering that occurs when the sun is transitioning (setting / rising)?
If not, is there a method to determine which of these floodlights have been designed to not flicker during the sun's transition?
https://www.homedepot.com/s/dusk%2520to%2520dawn%2520floodlight?NCNI-5
I am speculating that positioning or shielding the photosensor so as to minimize light originating from the bulbs is desirable. Any links to good t fixtures / sensors, you have installed are appreciated.
  • Of the sensors I install the sensors do not cause flicker but I have seen some LED lamps that have horrible flicker problems when first turned on, if the fixture is under warranty I would return it as the flicker tends to get worse with time or I have seen that. It got so bad I had to remove the fixture. – Ed Beal Jan 11 at 15:04
  • @EdBeal Any links to good sensors or fixtures are appreciated. Thank you – gatorback Jan 11 at 15:06
  • I have had really good luck with Tork 2021 sensors for 120v circuits these are slightly cheaper than intermatic and I have had a lot of failures lately with intermatic, these are listed for 600va for LED, 2000va for tungsten. As far as quality fixtures I purchase primarily from LEDmyplace.com , mostly DLC listed fixtures so there is a 5 year warranty and the few problems I have had with shipping dammage and a failure after only a few minutes they took care of me right away. I have now ordered several hundred lamps and fixtures from them and found them to be good quality at a good price – Ed Beal Jan 11 at 15:23
  • I've never installed one that flickered. That is the mark of pure junk (or just an honest defect). I wouldn't even expect flickering from Feit Electric, and that's a pretty low bar. Don't o keep in mind we are not a product-reco site. I bought this Cooper/Eaton unit but also had 1 of 2 fail in weeks. – Harper Jan 11 at 19:15
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
