Why do I have two overflow lines plumbed from my hot water heater. I know what the one is for the pressure relief valve, but I have another one plumber directly after the shutoff valve on the cold water inlet. This one drains all the time outside and I am not sure why. It is not necessarily hot water coming from it as it is backing up in the cold water inlet. I have not been able to find any information on why the second overflow line would be plumbed and why it runs continuously.
Thank you for your feedback
    What kind of hot water heater is this? is the second line "running all of the time" a condensate drain? Can you share the make and model of heater and the fuel source? – noybman Jan 6 '19 at 20:59
  • Does your water heater have a thermal expansion tank? This would be installed on the cold water inlet after the shutoff valve. – BillDOe Jan 6 '19 at 21:11
  • it is an electric water heater. Yes, the overflow line that is plumbed directly after the shut off valve runs water outside all the time. It is plumbed as a small water line, not like the overflow PVC line for the pressure relief valve. It actually comes out of the side of the house with the overflow PVC line. – Robert Jan 6 '19 at 21:11
    Can you take some pictures? – HazardousGlitch Jan 6 '19 at 21:49
    ... might it be a malfunctioning backflow preventer? – Daniel Griscom Jan 7 '19 at 0:06
