There is no screw (or covered screw) to remove the handles from this sink. I do not know the brand name.
Update: I figure it out how to unscrew it.
  • Looks like there is to me. On the right handle pictured, is that a hole? approx 1/16" wide? look inside, it probably needs an allen key wrench. – noybman Jan 5 '19 at 22:42
  • Thank you. I have figure it out how to unscrew it. – RShun Jan 5 '19 at 23:38
    Hello, and welcome to Home Improvement. Since you figured it out, would you post your solution as an answer, so others can benefit from your knowledge? Thanks. – Daniel Griscom Jan 6 '19 at 1:38
  • remove the cap. And then unscrew it. – RShun Jan 7 '19 at 3:50
