I'm putting a bathroom in my basement. Should my ejector pit be ready to use? There's a plug on the inlet that I probably can remove but there is a rubber gasket in the bottom of the tank that seems to need to be installed. The problem is the 4" pvc inlet pipe doesn't come out to allow the gasket to be installed. Should I worry about this gasket?
  • Hello, and welcome to Home Improvement. It isn't clear what you're talking about; adding a picture to your question would really help. – Daniel Griscom Jan 5 at 13:15
