I have solved the power outage to the circuit powering 3 different rooms but only partially. 2/3 outlets power on and 1/2 of the light switches work. In the bedroom. The working outlet is the only ‘ half switched’ outlet in its circuit. The adjacent bathroom’s light switch working but the GFCI outlet doesn’t. Even more confusing the one other bathroom’s GCFI is also dead. BR1 & B2 are on two separate circuits or so I thought. What circuit in the breaker would be powering the just the gcfi outlets then? Everything else up and downstream of GCFIs path is working properly. How could this happen?
  • We'll need pictures looking down inside each of the junction boxes. – Harper Jan 5 at 2:35
