We've just moved into a new flat and bought a new washing machine. The provided cable isn't long enough to fit to the water outlet.
I bought an extension cable, along the lines of this: https://www.bunnings.com.au/kinetic-1000mm-flexible-water-connector_p4750083
But I'm not certain if these needs to go before or after the Aquastop. The Aquastop is the electric variety but there is no additional cable to the maschine.
