Last winter, the water pipe in my garage was apparently not emptied entirely and burst when the water froze. At least that is what I assume, because when I turned on water in spring, it sprayed out of the wall.
Aside from hiring a professional to fix it, what options do I have? I'll probably not be able to fix the pipe myself, but it would be good if I could at least figure out where it burst and if it is only in one place or several, so that I can understand what the damage is and get an estimate of the costs I'm facing.
If I can combine this with preventing the same problem from happening again, I'll be happy.
(if it matters, the pipe runs from the house, is apparently dug deep enough in the yard, but of course has to come up into the wall inside the garage. The water spray was in the corner where I strongly assume the pipe coming up, because it's right next to the sink and toilet.)
