Frigidaire stackable washer/dryer
The washer does the wash cycle normally and drains the water. Then it re-fills for the rinse cycle. The motor clicks like it is trying to transition to the spin phase but will not spin. I can manually go to final spin phase and it will spin and drain. However the entire cycle will not run all together.
  • Hello, and welcome to Home Improvement. It'll be tough to diagnose this remotely, but either there's some issue with a sensor that is preventing the cycle from continuing, or the controller board has some sort of problem. More info might help. – Daniel Griscom Jan 2 '19 at 23:40
