I wish to have a motion sensor on the lights in my garage, but I also want to have an override switch that works normally, and does not require a specific pattern to toggle the override in the sensor.
Is this circuit workable?
/ Wall switch
+------0 0-----+
--Phase-+-----Sensor-----+-------+
| | Lights
--Neutral------+--+--------------+ |
--Earth------------------------------+
The lights are 4x flourescent tubes in two double fittings, but I may add more later. Or may replace with LED fittings if that helps.
Essentially I'm trying to replicate the function of an Occupancy Sensor wall plate, like this:
For some reason these aren't available in New Zealand. Voltage is 230 VAC at 50Hz.
The main reasons for concern are that:
- the sensor will have live voltage on both sides even when the sensor is off.
- the lights will not be isolated from power simply by turning off the wall switch. Adequate labelling at the lights should cover this
("WARNING DUAL SUPPLY! Disable sensor AND check for voltage before servicing.")
Related to but not a dupe of
