My house has mostly AC/BX wiring. I have added a light to an existing lighting circuit and pulled #12 Romex into an existing metal box. Problem is, this box has no 1/2" or standard size knockouts. It has only the smaller AC knockouts. I need a snap-in cable clamp to properly ensure my non-metallic insulation doesn't get cut on the metla box opening.
I feel like this would be a nornal request but the folks at home Depot looked at me like I was speaking a different language. I did find some 3/8" push-in cable clamps but they still looked to big.
Thanks!
  • I looked again. There is definitely a 1/2" knockout in that box, but I chose to pull the cable through the BX knockout, don't ask me why. Anyways, does such a cable clamp/gland exist to properly do this?
    – DrTarr
    Dec 31, 2018 at 21:53
  • So the Romex is already in and you want to fit a clamp without disconnecting and removing the wire? You might be able to enlarge the hole with tin snips and then fit in a two-part clamp, but I think you would find it easier to disconnect the Romex inside the box, pull it out, enlarge the hole enough to fit a cable clamp, then re-install the Romex. Dec 31, 2018 at 21:56
  • Actually, I can disconnect the wire. Problem is I can't remove the box without tearing out lots of drywall, so it has to be a snap in and not a two part clamp.
    – DrTarr
    Jan 1, 2019 at 13:44
  • Old thread I know but this may help someone else. Look at this box at Home Depot. RACO 2-Gang Electrical Square Box with NMSC Clamps and Bracket
    – Bob
    Feb 1, 2023 at 21:27
After looking at the comments, the real problem isn't the knockout, it's a clamp that will work with access only to the inside of the box.
Luckily, this is a solved problem. There are plastic push-in NM connectors made to install inside the box, such as the Raco Insider:
Raco Insider
This will install in a standard 1/2" KO.
This is a very common problem, so connectors that will work with cables fished into boxes are available almost everywhere electrical supplies are sold.
Big box stores are basically self service, I am sure there are exceptions, but I wouldn't expect ANY technical expertise from the staff. I've even seen egregious code violations in DIY videos on their official Youtube channels.
    My local electrical supply house manager confessed to me that he regularly trolls big-box looking for anyone competent, and hires them away. Clerks who remain at Home Depot are the "rejects". Home Depot is good at pre-employment screening, so has done that job for him! Apparently that's SOP in the supply house game. HD only really wants stock boys. Jan 1, 2019 at 18:08
    Thanks. I'm aware of 1/2" knockout plastic and metal snap ins. What I was specifically looking for was this exact thing for an AC/BX knockout, which is much smaller. I am thinking they just don't exist.
    – DrTarr
    Jan 1, 2019 at 18:49
