I installed new flooring. The existing toilet flange is recessed - see picture. The flange is glued into and existing outlet and I don’t see a way of removing it without cutting the pipe lower down and making a new outlet. An alternative is to cut the top of the flange and add a new flange with a smaller outlet - there are flanges that fit within a 3 inch outlet. Would this work? Also, would I need to build up the subfloor or can I still have it recessed? enter image description here enter image description here
    Doesn't look like anything is wrong with the flange itself. How far down is the top of the flange from the new floor? Commented Dec 31, 2018 at 15:09
  • About 0.5 inch from top of flange to top of new floor.. I used a large wax seal before and it worked well.. Commented Dec 31, 2018 at 17:47
Your original flange looks like it's in perfectly good condition, so I wouldn't try to remove & replace it.
Instead, I would use a Flange Spacer like this:
or one of these:
  • I would disagree it is way to far below the surface to make a seal with even a 2 seal hack!
    Commented Jan 2, 2019 at 4:38
  • @EdBeal - the OP says in a comment that it's only recessed a 1/2", and a "large wax seal" worked previously...
    – brhans
    Commented Jan 2, 2019 at 14:35
A half inch of space isn't very much. You can probably use a normal size wax seal and be fine or you can go with a extra thick seal to be sure it seals properly.
