I have 3 wires coming out from the wall at my new house (red, white, blue). It is a water boiler heat only system. The tstat was already removed unfortunately.
I thought the blue wire was the C wire, so I hooked it up to a nest but it didn't work. It said there was no power.
I checked the voltage as following:
  • red and white: 24V
  • red and blue: 0V
  • white and blue: 24V
I put R and W together and the heat is on.
So I think the blue wire is not a C wire? because it looks like it is hot. So what is this blue wire for? or I think the red and white are somehow swapped... so white is hot and red is neutral? At the relays, does it matter which wire goes to the terminals? It is a heat only boiler system, no cooling.
These are the wires from the relays. Zone 3 is the zone. I don't even see any blue wire.
    Can you post a photo of the wiring at the zone valve or circulator pump? – ThreePhaseEel Dec 31 '18 at 2:32
    Hello, and welcome to Home Improvement. Looks like you've created two accounts. You should use the Help/Contact page to ask SE to merge them. – Daniel Griscom Dec 31 '18 at 20:29
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
