I want to ask HVAC experts how to troubleshoot my floor heating system. I have a Lynx-85a boiler, pumping hot water into three zones, one per room and three zone valves. For some reason, original builder installed four thermostats. There is a main thermostat in front of the boiler room. It controls cental air conditioner that has no zones.
I tried to replace living room thermostat and it only has ~2V. Yet, it works just fine. It has two AA batteries and seems to be able to control zone valve. The other two room thermostats and main one have ~24V. I am confused about how the system is set up.
help grealy appreciated.
i took a picture of my zone valves and a page from lynx manual. i am not certain how it is setup.
  • If the thermostat uses 2 wires, connect to R and W. A third wire C is usually needed for digital stats. Voltage is checked between R and W or between R and C. Look for 24v a.c. when the stat is off. Your diagram shows 2-wire stats. A 3-wire setup would include a C wire from the bottom of the transformer winding. The cool stat would also include a Y wire for cooling call. – John Canon Dec 30 '18 at 5:12
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
