This old Lennox furnace has no c terminal. I can run a wire directly from the furnace to the thermostat. Question is, which terminal do I hook it to?
Look more widely, it may not be in the usual group of terminals, since traditional thermostats did not need it. Is there a transformer in the furnace somewhere? – Harper Dec 30 '18 at 3:12
Can you post the wiring diagram for the furnace and/or photos of the wiring at the furnace? – ThreePhaseEel Dec 30 '18 at 3:16
