I have what appears to be black mold growing on my porch ceiling. What is your recommended method for correcting that problem? The ceiling is white.
  • Is your porch enclosed or outside? Adding a couple of pictures to your question would be a good idea please. – Criggie Dec 29 '18 at 21:35
I had black mold in my sunroom, and my solution was to hit it with bleach (mixed with water), then to scrap it off and remove it from the areas. I then hit the area with "Mold Control" from Home Depot (as it helps also prevent the spread of mold. I did this to the effected area plus 1m on either side. Then I painted over it with a mold-proof paint (talk to people in your area who can best advise stuff for your region and colour).
I hope this helps. But importantly, use proper PPE use a mask that blocks that stuff and googles! Be safe man!
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming! – Daniel Griscom Jun 5 '19 at 15:23
If the mold is coming from humidity in the air, I would kill the mold with a 1:10 chlorine bleach solution and water, undiluted white vinegar, or use a commercial product made for killing black mold. Rinse, let it dry, and don't worry about stains. Use Kilz paint primer to paint over the stains. It is a pretty good product and covers over mold and other stains, including cigarette stink, cat/dog pee on floors, and numerous other sources of nastiness. Finish by painting with the appropriate paint of your choice.
If the mold is a result of a moisture leak from the roof above, you have a bigger problem. You will need to repair the roof first, then use the above method to get rid of and cover the mold.
I'd nuke it with either the pressure washer or some bleach, depending on the surface.
If I thought the pressure washer would damage it, I'd use the bleach. Pump spray a bleach solution followed by a brush then rinse. If I think the bleach would ruin it, I'd start with soap and a brush.
