Trying to help my dad install his new Nest thermostat - for some reason his thermostat has two wires going into the C terminal. I've searched and cannot find any other question about a setup like this.
I'm wondering what kind of system may have caused this?
My thought is to abandon the C wires altogether and just install the Nest without them, since apparently it's not required.
Thermostat wiring
  • One of the wires going into the C terminal is white -- what color is the other wire? Also, what do you have for an HVAC system? – ThreePhaseEel Dec 29 '18 at 14:21
  • Not at my dad's place right now so can't check the other color. It's a forced air natural gas furnace and central air. There's also an electric air cleaner with the furnace. Would it be wrong to pigtail the two c wires together? – Darrrrrren Dec 29 '18 at 14:47
  • The current setup is the equivalent of a pigtail. – bib Dec 29 '18 at 15:16
  • @Darrrrrren -- when you get back to your dad's place, can you check and see how many thermostat wires there are at the furnace? – ThreePhaseEel Dec 29 '18 at 15:19
  • @bib, yes, but the nest only allows one wire into each terminal. To get both of these in I'd have to pigtail them externally. – Darrrrrren Dec 29 '18 at 15:32
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
