If I drill a hole from indoors to outdoors and mount an exterior outlet directly over the hole, do I need to use outdoor cabling even though it's not exposed to the elements?
Although it's done that way all the time, it's my opinion that if the box is in a wet location, the cable inside the box must be rated for wet locations. Sometimes an easy way to comply is set a box just inside the building, and transition from NM to UF in the indoor box, send the UF out to the outdoor box.
    Or run it the last foot in conduit, and use THWN-2 individual wires. Dec 28, 2018 at 23:56
