When it gets cold out, about - 10°C, the interior walls are cold to the touch. Especially ones in the corners of the house.
What causes this? How can it be fixed?
Sign up to join this communityWhen it gets cold out, about - 10°C, the interior walls are cold to the touch. Especially ones in the corners of the house.
It could be just air leaks and simply caulking the exterior may remedy the cold areas completely. In addition to caulking, cold spots are typically due to the lack of insulation or a poor installation of insulation.
If caulking can't be put anywhere apparent or does little to nothing, then you'll have to rip the walls and corners open to air seal and insulate with the proper materials and methods.
There can't be any openings, gaps or loose fitting of insulation nor its seams and everything heading to the outside must be caulked.
