I had a new fridge installed and the plastic water tubing from the sink cold water connection was leaking behind the fridge when they installed it. I am going to replace the plastic tubing and wanted to install a shutoff valve so I would be able to turn off the water to the fridge without having to turn off everything else. The current shut off valve is connected to the tubing I will be removing and I am not a big fan of these types of valves. What is the correct type to use?
Thanks
