I recently had my bathroom renovated, including floor and shower tiles. I love the tile color, but the grout I chose dried a few shades lighter than I expected. I did some research and found that grout can be stained a different color (I.e. grout refresh by Lowe’s). I was planning to add a sealer anyways, so it didn’t seem like a big deal. However, it’s not just grout in all areas. They added caulk in the corners of the shower (the caulk is the same color as the grout).
If I do choose to stain it, or even add a sealer, will that work in the areas that caulk was applied? Do I need to re-caulk, or will the sealer/stainer work on caulk too? Thanks for any advice!!
EDIT: Here's what I used:
Grout: Polyblend "polymer-fortified" non-sanded grout
Caulk: Polyblend "siliconized" non-sanded ceramic tile caulk
