I have two switches at the bottom of my stairs in the basement. One switch is a three way to the switch at the top of my stairs. The other switch lights a series of lights all connected to the same circuit. One of those lights is in the pantry and what I would like to do is isolate that light from the rest by adding a single pole switch to the room. The switch at the bottom of the stairs would still light up the rest of the lights.
Do I need to run a separate hot from the existing box to the new box where the new switch in the pantry will be for the pantry light.at bottom of stairs looking at existing wall switches and looking into the pantry Power wire to existing pantry Power wire to existing pantry light Inside pantry looking at new switch box
    Please edit your first question instead of asking a new one with more details. Please do add the pictures to the first. – David Dec 23 '18 at 22:10
  • I added the pictures to the original post. I apologize for the duplicate. Learning the forum and wont happen again. – Christopher Lond Dec 23 '18 at 23:17
Whether you can simply break that light off the circuit and put it on a new switch depends completely on how the power is run.
If the light is fed in the ceiling, then yes you can just add a new switch.
Existing wiring:
wiring diagram fed through light
With the new switch:
wiring diagram with added new switch
However if the power comes through the existing switch then no you will have to run a new feed to the light. That feed can go through the new switch (shown in the bottom diagram), or straight to the light whichever is easier.
Existing wiring:
Beautiful MS paint wiring diagram
The new diagram for this scenario:
fed from the new switch
Who said MS paint couldn't be used for wiring diagrams...
| improve this answer | |
  • Please show these images to the original post. Thanks david! – Christopher Lond Dec 23 '18 at 23:17
