I discovered yesterday that led bulbs cause RF interference and disrupt the use garage door remotes. While I could look for a low interference led bulb, they are rather expensive. I had some cfl bulbs lying around, so I decided to try to use them.
One weird thing was that one cfl bulb worked, while the other cfls didn’t. This has nothing to do with the light switch. To test this, I turned the light on, and then tried various bulbs.
So the question is, why would this cfl bulb work on a garage door opener socket:
works
While this cfl bulb doesn’t work in a garage door opener socket (I tested it in a lamp and verified it is a functional bulb that lights):
doesn’t work
What is the technical difference between the two that makes the garage door operate with one, but not the other?
  • YMMV but 1) most garage door openers use an SCR (Silicon Controlled Rectifier) rather than a physical relay to switch the light on and off. This type of solid state relay doesn’t always play well with the electronics incorporated in non-incandescent bulbs. 2) the shape of the bulb tip that screws in may be deformed and not make contact 3) the bulb in a garage door opener is subject to vibration, typical CFL bulbs aren’t rated and won’t last long anyway in a door opener. 4) if your garage gets cold in the winter CFL is a bad choice as they don’t start well in cold weather.
    – Tyson
    Dec 23, 2018 at 15:22
  • What bulb do you recommend as opposed to cfl? For the record, I tried 5 other cfl bulbs that worked in a regular lamp, so I’m confident that the bulb that I took a picture of that did not work in the garage door opener was not deformed or defective in any way.
    – paneerlovr
    Dec 23, 2018 at 15:31
  • The center prong on the socket itself may be pushed down preventing contact as well. Both conditions are impossible diagnose from pictures. In my own garage door opener I use 67watt 130volt traffic signal bulbs. With 5 filament supports they are vibration resistant. The 130 volt spec also adds to longevity. Yes they are not energy efficient, but in total they probably aren’t illuminated more than 12 minutes per day, so the savings from better energy efficiency would be minimal. I haven’t changed a bulb in a garage door opener for the past 8 years.
    – Tyson
    Dec 23, 2018 at 15:43
  • I have a pair of LED bulbs in my Chamberlain opener. Remote range is half a block.
    Dec 23, 2018 at 16:09
  • When I have to change I’ll probably go to LED as well. LED bulbs weren’t very far along when I screwed the last set in 8 years ago.
    – Tyson
    Dec 23, 2018 at 16:21
How do I detect which bulbs will play well with my garage door opener remote? You find out which radio frequency your remote uses, tune a radio to that frequency, turn on a candidate bulb, and listen.
How do I detect this pre-purchase, say from a product listing on Home Depot's website? You don't. The needs of your garage door opener are poorly documented, and the RF emission band diagrams of random bulbs are not documented at all. Or even consistent enough to document! Nevermind manufacturing inconstencies, nothing keeps an LED marketer from changing internal parts and completely changing the RF frequencies it emits.
Now, about this:
That's a blanket statement, and it's not true. Here is what is true:
  • High frequency electronic devices tend to emit radio frequency interference on the same frequencies, unless shielded. If on the same frequency as your remote, it will drown out the weak remote signal.
  • CFLs, by nature of their design, must generate high frequency signal which is not practical to shield because it must reach the tube. That frequency does not need to be high enough to interfere with garage doors, but that's cheaper.
  • LEDs natively want 3 volts DC, so no frequency at all. The problem is voltage conversion, most cheaply done by using a high-frequency chopper circuit, the higher the cheaper. This can be shielded, not for free.
  • For the cheapest bottom-shelf consumer bulbs of both types, it's a game of pennies. A shortcut that cuts manufacturing costs by 0.1 cent per unit will tend to be taken.
  • The FCC calls for shielding as part of its Part 15 certification, but this may not be enough to prevent interference. Some cheaper manufacturers fake this certification.
The answer is to redline CFLs immediately, and look for LEDs that have been designed with care to not create this high frequency interference. These will be consciously designed products, and will not benefit from the extreme "optimizing for cheapness" that our Chinese, um, allies are so fond of putting in products marketed to us.
Both CFL and LED's have electronics that could cause issues. To limit the possible problems the FCC has listing requirements that limits the emissions so if the lamp is UL listed it would meet the noise requirements and not be a problem. Off brands imported directly without meeting requirements may cause problems. In both cases since your existing good lamp is not working find a dimmable lamp, these lamps can work with electronic switches that affect the waveform where non dimmable may not light at all.
