I have a stove I am replacing that was direct wired. When I went to put an outlet in, I found out it only has 3 wires, Black, Red, and White and no ground. I have a hood right above it that is grounded.
Can I run the ground wire from the hood to the metal stove outlet box, bond it to the box with a screw in the back, and then to the ground terminal of the outlet for my stove?
I am a layman, so please keep it simple. Thank you in advance for any help.
