I just bought a home and it desperately needs an update to its heating. It currently has baseboard electric resistance heaters in every room. There is no duct-work in the house. We're in cold humid climate with expensive electricity (Ottawa, ON, Canada). The house is 2 levels + basement:
Central heating isn't out of the question, but I'm under the impression that retro-fitting duct-work would be prohibitively expensive/big job, and I like the idea of zoned heating to minimize wasted energy (and$$) as much of the house will be un[der]used. Eg, the office only needs heat during the weekdays.
These are the options I'm aware of:
- Install duct-work and central gas furnace,
- Install cool-climate multi-head ductless heat-pump to heat and cool the most used rooms (up to 4 heads I think?),
- Install gas fireplace heating (possible locations shown on floor plan),
The question is: a) what other options exist, and b) what combination of these (or other suggested) options can be installed to provide the best heating solution. "Best" will be defined as the solution that minimizes costs over 10 year period while maintaining a comfortable 20degC on the main floor and master bedroom.
As a starting point: my thoughts were to install a gas fireplace in the lounge and create a vent in the adjacent wall to blow cold air at the fireplace from the kitchen-dining room. That should add some needed circulation. Then install a heat-pump to handle the guest/master bedrooms and office. The rest would keep the baseboard heaters.
