Every single home I've visited in the US has one of these two light switch designs:
In contrast, homes in Europes usually have their light switches designed like this:
Is there a practical reason for this difference? Could I use a European light switch in the US (or vice-versa)?
    It looks like the European switches are designed for smaller wall boxes, or they may be designed for surface mounting on a special plate. "When in Rome, . . ." – Jim Stewart Dec 19 '18 at 18:06
    a lot of things are different in europe than NA, it's often more accident than design; railroad gauges, side-of-road, coin denominations, toilets, lock cylinders, etc... – dandavis Dec 19 '18 at 20:25
    Because they evolved in different halves of a planet not connected by an internet? – isherwood Dec 19 '18 at 21:00
  • Side of road is same in europe, except UK – Jasen May 13 '20 at 21:55
Generally speaking no*.
Europe and the US have different voltages (230v vs 120v). This puts different requirements on the equipment, and they will be built and rated to suit these. For electrical purposes, if it isn't rated nothing else matters.
ie. a 230v circuit at 10A requires a much lower cross-sectional area of conductors but a higher insulation requirement, with the opposite being true for at 120v.
*It is of course possible to build a switch to meet these requirements and they may well exist, but the answer to "are they interchangeable" is no.
    Australia, New Zealand, and most pacific Islands use 240V and US sized electrical boxes. – Jasen May 13 '20 at 21:54
  • Standard North American electrical boxes are used for 277V circuits in commercial work all the time -- it's not uncommon to find spec-grade or better light switches, as well as multi-volt ballasts/drivers and commercial lighting controls (dimmers, timers, and so on) that are happy at any voltage between 120 and 277V – ThreePhaseEel Jan 14 at 0:45
Yes, because it also allows this:
Note the two sockets, which we have found to be indispensable. That's one standard yoke, and all junction boxes therefore are designed to accommodate that one yoke. Here's what it looks like naked.
That, by the way, is a 20 amp variant of that same plug, note backward compatibility. Many circuits are actually 20A wired (for which we use stout #12, 3.3 mm2) and either socket is permitted on them, all 15A sockets are internally built for 20A. Appliances which require 20A keying are scarce as hen's teeth, though.
Also, multi-“gang" boxes are built with a standard spacing. Why? Because cover plates are generic and interchangeable: there are a limited number of opening shapes, and you've just seen them all. The small square and dual ovals are traditional, and Leviton invented the big rectangle "Decora" so they could accommodate just about anything. Up to about 3-gang, you can get almost any combo, but then you reach a point of diminishing returns. So if your combination is too eclectic, you just switch to all-Decora type, and do this.
by the way, if you need to plug in a Euro appliance, and it won't be spun to death by our 60Hz power, we have ways to do that in our plug/socket regimes, using NEMA 6, the 240V versions of the above sockets, good for up to 4800 watts. Surely you don't think we'd allow a ”power gap”?
Anyway, you want to plug in a Euro style switch. There's one gotcha.
110.2 Approval. The conductors and equipment required or permitted by this Code shall be acceptable only if approved.
"Approved" means by your local permit/inspection office. They do not run a competent testing lab, so they delegate to agencies like Underwriter's Laboratories (UL). These marks used to be very nationally provincial. But thanks to trade deals like NAFTA, GATT, G7 and all that jazz, countries whose standards are comparable recognize each others' approvals.
So you would need to bring over approved (surely anything sold at Wickes would be approved) junction boxes and switches from Europe. Most likely our Romex cable would be a viable substitute for twin-and-earth, though our fat wires might have a problem fitting your terminals, especially our gratuitous use of #12 on what would be a 13A circuit in the UK.
    This doesn't necessarily say why the design is different between the US and Europe - it only alludes to why the US devices are designed the way they are. Does the European design not allow switches and receptacles to use the same j-box and cover plates? Is there another consideration for the European design that the US doesn't need to deal with? – mmathis Dec 19 '18 at 18:33
  • @mmathis because I wasn't finished. I am having to work on an ipad, and when I have to do heavy hunting down of images and editing them, the ipad runs out of RAM and deletes the browser tab, forcing a reload when I return to it. The reload deletes my work, so, frequent saves are necessary. – Harper - Reinstate Monica Dec 19 '18 at 19:06
  • I have an Australian dual 10A outlet here, the apertures for wires are about 5.5mm diameter, so 4 AWG12 wires would be a tight fit, they're only slightly larger than the 2.5mm^2 wires we normally use. – Jasen May 13 '20 at 22:26
  • @Jasen 12 AWG wires are 2.05mm diameter and 3.3 mm^2, so one ought to fit just fine in a 5.5mm hole. Whether you can put 2 or more wires in that hole is an interesting question; since our Code does not allow it unless the NRTL-approved instructions authorize it. – Harper - Reinstate Monica May 14 '20 at 1:52
  • these holes have scews that clamp the wires and are intended to be usable with multiple conductors. – Jasen May 16 '20 at 12:47
You COULD use an EU designed switch here, functionally they are identical. But practically it's not going to work because you would also have to import the boxes to mount them in, their switches will not have the right holes / sizes / fill limits as what we use here.
    And the boxes and switch units will probably not meet US code requirements, even though they may be functionally adequate. – bib Dec 19 '18 at 23:29
American style wall boxes are easily modified to accept the more attractive EU switches. Wiring them in is standard. Both EU 230 and USA 120 connect the same way. If you choose to use EU switches in the USA just buy the EU boxes at the same time you buy the switches and it's a plug and play operation.
    But, as others have suggested, you may then violate building regulations. – Chenmunka Jan 13 at 18:27
    And, "more attractive" is well within the eye of the beholder. As an American, used to American switch gear, I found the Euro switches/outlets rather funny looking and thought it was inconvenient to only have one outlet/receptacle instead of our US style duplex outlets. – FreeMan Jan 13 at 18:33
  • I'd be a bit skeptical of that -- cableclamping and KO sizes are likely to be tricky, and the way we use conduit and metal-armored cables in parts of the US is somewhat...alien to EU sensibilities (SWA is a thing, but it's a rather different beast than AC or MC) – ThreePhaseEel Jan 14 at 0:51
