I bought a light fixture for my bathroom and noticed the screw holes on the fixture are in a N/S orientation, while the junction box is in an E/W orientation. I am able to rotate the existing bracket to accommodate the different orientation (the one that came with the fixture is too small), but I'm wondering if I should replace the current box with one that has a N/S orientation, or if I can screw holes through the drywall to hold the fixture. I did rotate the one piece of the bracket to go into a N/S orientation, so I could attach the fixture to that, but that part of the bracket doesn't screw into anything behind it. The fixture will go on the wall, not the ceiling.
1I think that fixture is missing an important piece. Notice how the cables enter the fixture in 3 places. You can't just shove that up against the ceiling, there needs to be some sort of enclosure to protect the 3 cables. Was this bought off ebay/Amazon/Aliexpress? Bargain "opened box" deal?– Harper - Reinstate MonicaDec 18, 2018 at 16:58
It's on the wall, not the ceiling - I say that in the last sentence of my post. I bought this new fixture from Lowes, unopened.– WalterDec 19, 2018 at 2:39
Ok nevermind, I see now the fixture has sidewalls which enclose a substantial void, the wiring goes in there. It is rather odd that the only attachments are in the center.– Harper - Reinstate MonicaDec 19, 2018 at 5:22
There is a round plate adapter made to give you the right orientation. Any lighting supply house can help you. Good Luck.
2The thing you're looking for is called a "universal crossbar", by the way. Dec 19, 2018 at 1:08
There is no code or rule that says you can't mount a fixture directly to the dry wall. I would use something like a 4" toggle either 1/4 or 3/8. But as @Harper has pointed out there are codes and rules about using that space for a junction area. This is one I would run by the AHJ first.
