  • Does any vendor make a wall receptacle for bathroom use that provides GFCI, surge protection, and USB ports?
  • Can you plug a surge protection strip into a GFCI?
If I am understanding the inherent capabilities of each, it may not be possible to do GFCI and surge protection simultaneously, but i wanted to ask the experts.
closed as off-topic by Daniel Griscom, ThreePhaseEel, mmathis, Tyson, Machavity Dec 18 '18 at 0:29
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions seeking product or service recommendations are off-topic because they tend to become obsolete quickly. Instead, describe your situation and the specific problem you're trying to solve." – Daniel Griscom, ThreePhaseEel, mmathis, Tyson, Machavity
If this question can be reworded to fit the rules in the help center, please edit the question.
  • Hello, and welcome to Home Improvement. Unfortunately, "shopping" questions are off-topic here. Please take our tour to learn more. – Daniel Griscom Dec 15 '18 at 19:07
Of course it's possible to cram everything into a box, but it's not necessarily wise or constructive. It's perfectly possible to put those things elsewhere.
The GFCI
A great deal of confusion about GFCI arises from most people being acquainted with a combination device which has both a GFCI unit and a receptacle. They think the two are one and the same.
Actually, a GFCI unit is nothing more than a black box, which provides GFCI protection to downline loads. Electrically, it looks/works like this.
(Disregard red, blue, yellow and orange; you don't have them.)
They are simply taking this black box, sticking a couple sockets on the right side, and selling it as what you know. Actually that GFCI can be a standalone module, or even part of a GFCI+circuit breaker combo device down at your panel.
All this to say, the GFCI does not need to be at the socket location. It can have its electricity fed from a GFCI in another location.
Surge protection
This is even easier. The surge protection provided in cheap power strips is rubbish. Presumably you are trying to protect your equipment from surges from other faraway equipment, not your equipment itself. They also make commercial grade surge suppressor modules which can be attached at any accessible junction box along the circuit, or the panel itself. These are sturdy modules that will provide lasting protection.
USB sockets
With the surge protection and GFCI offsited somewhere upstream in the circuit, you are now free to use any common USB receptacle or USB/NEMA 5 combo receptacle.
  • Fully agree, surge protection at the panel is the best and safest way to go (have seen two many of the plastic ones melt) and using down stream USB from a gfci protected circuit+ – Ed Beal Dec 15 '18 at 21:01
