What is the name for the type and style of the tiles in the photo below?
I couldn't find anything with reverse image search and no one I've talked to knows. The photo is from an MLS listing. The home's owner is deceased so can't be contacted. The home was built in the 1950's although these tiles might not be that old as they look to be in great shape. Any clues?
closed as off-topic by isherwood, Tyson, Daniel Griscom, Machavity, mmathis Dec 15 '18 at 20:27
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Not enough information was provided to answer this question accurately. Please include the make and model of all devices and equipment, photos, diagrams, drawings, and any other information that might help people provide an accurate answer." – isherwood, Tyson, Daniel Griscom, Machavity, mmathis
If this question can be reworded to fit the rules in the help center, please edit the question.
  • Looks like common glazed ceramic to me, though it could be porcelain. Hard to tell from back here. It has a wide color spread, but that's not out of the ordinary either. It could be that several colors were mixed. – isherwood Dec 12 '18 at 14:09
    Likes like lino (linoleum) to me! – AndyT Dec 12 '18 at 14:57
  • i agree with @AndyT 's observation .... the pattern repeats – jsotola Dec 12 '18 at 20:06
  • It's not linoleum. It's grouted tile. I agree that it's a ceramic tile, but is there a name for this specific style? There are major color variations on each tile, and the tiles themselves vary. – Nick Dec 14 '18 at 23:12
The image is low resolution and warped, but it appears like the tile patterns repeat in different orientations. This suggests it is not linoleum, where the patterns are likely to repeat in identical orientations and less frequently. The more than slight reflection of the white appliance also shows the flooring has more shine than plastic flooring like linoleum or vinyl. You can also see the primary light source is coming from significantly higher above and behind the camera (by the shadow under the cabinets). The tiles appear to follow this shadowing, strongly suggesting they are significantly raised (approximately .33 inches or higher each).
Because of all this, it's probably regular ceramic tile.
