I'm working to fix a free hot tub that I got with a number of issues.
Now it seems that my heater is not working and also making a clicking noise. I am wondering what peoples thoughts are on what this could be? It's definitely coming from the heater area (not the motor) and I'm concerned it's arcing.
I imagine this could be a useful question for anyone trouble shooting an electric coiled water heater. The link to the video is below.
https://www.youtube.com/watch?v=Xwyenfw0Co0&feature=youtu.be
Thanks so much stack exchange community
The clicking noise sounds like a contactor or power relay. On the tubs I have worked on there has been a safety pressure switch on the pump, no pressure the switch opens and the heat contactor drops out. Other possible problems include a rusty contactor trying to pull in, loud buzz because it's not fully closing. I would check the pressure switch and look for a possible thermal overtemp switch also. Loose or corroded connections are quite possible also. So an inspection of the connections could also identify the problem. The contactor issue needs to be fixed but you can test the heater with the power off, measure the terminals with an ohm meter the value will probably be 10-30 ohms if it shows open it is bad. The resistance is based on the size of the heat element so it could be lower or higher but will probably be close to 10-30 ohms. I have bypassed both pressure switches and over temp switches to verify that is the problem but once solved never leave a safety bypassed.
| improve this answer | |
