I'm building a custom deck stairs lighting system. I have purchased RGBW 40mm diameter waterproof LEDs and want to install them in the stair risers.
https://www.aliexpress.com/item/DC24V-RGBW-DMX512-UCS512-chip-5050-SMD-addressable-pixel-module-7-piece-of-5050-SMD-LED/32896759636.html?spm=a2g0s.9042311.0.0.4e394c4dL2z0e9 enter image description here
But can't find any resources on where to get face plates enclosures etc.
Any resources exist for creating custom outdoor lighting enclosures with diffuser plates? Any hacks people have used to repurpose parts meant for other uses? ie stainless steel grates and grills.
  • Unless the manufacturer of the lights makes a specific enclosure for those ( and the wiring ) then it is unlikely that someone else does. You may be best served to get some that are specifically designed to be used outside in a wet environment. – Alaska Man Dec 11 '18 at 22:23
