I'm rewiring outlets and switches in our 1960's California home using AlumiConn connectors to connect the aluminum wiring to copper pigtails. Most cases are straightforward, but I've run into a case where a box (a double-sized box, thankfully) includes a joint of the neutrals of 4 aluminum wires (10 gauge each). AlumiConn's only come with a max of 3 ports.
What is the correct way to handle 4-wire connections? Is it correct to daisy chain the AlumiConns?
Lacking any other instructions, my instinct would be to wire them like this, but I don't know if this is acceptable, safe or correct:
AL AL CU AL AL
,--._,--._,--. ,--._,--._,--.
| AlumiConn | | AlumiConn |
