I have a 6.5KW generator and wonder should I use the 120V 30 amp receptacle to hook to house panel or the 240V 30 amp receptacle?
  • a) 120 X 30 = 3600 which is not enough to use all your available power, b) with 240v and the right connection you could power 240v appliances which is not an option with only 120v connection – manassehkatz-Moving 2 Codidact Dec 11 '18 at 1:11
  • Can you post photos of your receptacles? Also, I take it you have an inlet and transfer switch/transfer interlock fitted to your house already? – ThreePhaseEel Dec 11 '18 at 4:54
The 240-volt power supply will always be better and supply more power to your house. Please take note however you need one more rather sophisticated item it the mix to make a safe system. You need some type of a transfer switch to make your system safe and to keep your generator power from energizing the utility power grid. You can plug individual appliances into the generator just as is. But if you want to connect to the house panel, you need a transfer switch first. Most places this is the law. Without it people can get hurt.
| improve this answer | |
