I'm collecting greasy/contaminated construction textiles (shirts, rags etc) in a dedicated bucket and not with general laundry. Is there a recommended general (meaning it works with most types of contaminants) treatment for such textiles before they are safe to put in a regular washer? Like soak it in some chemical to release the gunk.
closed as off-topic by isherwood, Daniel Griscom, Machavity, mmathis, Tyson Dec 12 '18 at 21:55
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions seeking product or service recommendations are off-topic because they tend to become obsolete quickly. Instead, describe your situation and the specific problem you're trying to solve." – isherwood, Daniel Griscom, Machavity, mmathis, Tyson
If this question can be reworded to fit the rules in the help center, please edit the question.
I would wash them in a bucket or tub with plenty of detergent and water as hot as the garments can take. Then rinse them with a hose onto grass or soil. Check to see if grease is removed before putting in the regular washer.
I use simple green when I get really greasy I do adigitate it and dump it prior to putting in the washing machine but the simple green works well at breaking down the grease and simple green is non hazardous.
