I'm in the process of restoring an old Bench Vise and first I'm disassembling it, so I can check parts for excessive wear, remove rust and repaint. I'm not sure what is the brand, but here's a picture of it:
I could remove a plate that holds the dynamic jaw to the main frame, letting it slide and not allowing it to move up. Below the dynamic jaw already without the guiding plate:
But the spindle is somehow fixed inside the dynamic jaw. I could notice two small holes, after removing some grease, on the bottom (picture above), and two small holes that I had to scrap rust off on the top in the same axis.
I suspect there are some pins inside there holding the spindle, not sure how though. Before I started hammering a small nail inside it I thought someone could answer if they've ever seem this kind of spindle fixing before, how it works and how to remove it/replace it.
Any ideas? Thanks!
