I am planning to fit some binders to support sagging ceiling joists and want to know the best way to join the joists to binders.
The joists are C16 4x2 and span over 4 meters! The house was built in the 60ies and the sagging has caused the ceiling to crack right down the middle. Its a small crack but it is developing.
There is a binder that runs half way over the existing joists but it does not look like it was fitted properly as some joists are not attached to it (I can see gaps) and one end of it does not rest on the load bearing wall.
I am planning to run 2 additional 4x2 binders and just want your opinion on the best way to attach them to the joists.
I am thinking about using these (in order of preference)
Stainless Steel Banding 20mm - Run under the joist and then twist and wrap around and over the top of the binder and screw.
Angle brackets
Truss clips
Skew screwing from the joists to the binder.
Loft is used for light storage and is boarded.
Thanks!
