This wall rack does not have any screws showing in the i
Any ideas of how to get it off the wall?
Thanks
    Have you tried sliding it up on the wall? Mounts where the screwed in braket is hidden often involve pushing the shelf onto a mount then sliding it down to lock it in place
    – Jaydles
    Dec 8 '18 at 22:11
    @Jaydles Way to go Jaydles! Who knew you about that stuff.
    – bib
    Dec 9 '18 at 1:38
  • @bib, I had a good teacher. ;)
    – Jaydles
    Dec 10 '18 at 0:13
Many fixtures with hidden brackets - especially bathroom fixtures - are secured with a set screw into each bracket. Check the underside on each end of the shelf for a small screw. These are usually slotted or hex screws, usually no more than 1/2" in length. You may need to back the screw out almost all the way, as there is sometimes a lip it has to clear.
  • Thank you for your answer! It was the tiny hole and was a spring release so it took a bit of coordination but we got it off!! WooHoo!! Thanks again
    – Lchpitt
    Dec 9 '18 at 18:34
