I would like someone who is smarter then me to let me know if this current wiring setup would work with the Nest Thermostat?
Thank you for your helpenter image description here
  • Yes, it is compatible. – Simon Arsenault Dec 5 '18 at 16:45
  • Are there unused wires back there? – ThreePhaseEel Dec 6 '18 at 0:20
  • Will i need to use a jumper wire to setup the Nest? – C Fella Dec 12 '18 at 22:31
You should take a look at the Nest Compatibility Checker to be sure. Based on having G, Y, W, R, and a jumpered Rc wire, it looks like your setup is compatible.
Note that Nest has an internal battery and does not require a C (Common) wire, but it is better to have one if you able to add it (with a currently unused wire, for example).
