I've purchased a 55" TV and a pull-down mount to put over my fireplace so I can pull the TV down when in use and guests won't have to crane their necks. This is the overall layout of my fireplace and room (please forgive my amateur SketchUp mock):
Unfortunately, the drywall above the fireplace is attached directly to the brick with no studs in between. I understand that some mounts can be mounted to masonry, but with the additional force from the pull-down mount, I'm not comfortable with this solution (and neither is the manufacture).
So instead, I'm using this predicament as an opportunity to build a fireplace surround, and bump out the area above the fireplace with a new stud wall in front of the existing drywall. Sort of like this (sorry, SketchUp merged my studs together; the outer full-height studs are meant to be king studs with jack studs nailed to them, and a 2x4 "sill" connecting them on top of the jack stud):
The bottom of the king/jack studs will be hidden by the fireplace surround. There are studs on either side of the fireplace, which I was thinking I would attach the new king/jack studs to. I would drywall the area above the surround for a finished look.
Here are my concerns/questions I'm hoping you can help me out with:
  1. Am I overthinking this? Should I just build a framed box like this and attach it to the studs on either side of the fireplace? Will this be strong enough for a pull down mount and TV, if my new framing is only attached to studs on either side with bolts?
  2. How would I go about attaching a new stud wall adjacent to an existing stud wall, anyway? I have a stud behind the drywall, skinny side facing the drywall backing of course, then drywall, then a new stud oriented the same way... do I somehow run a bolt through all 7+" of material??
  3. Do I need to cut away the drywall/ceiling to build this new stud wall, or can I attach it to the joists/studs through the drywall?
Thank you in advance for any help you can offer!
Without seeing what's underneath, I think I'd build the box and attach it to the wood studs on the sides of the fireplace chimney. You could do the actual attachment with short 2x4s perpendicular to the existing studs rather than trying to bolt the long sides of the studs together. It kind of depends on how much space you have in there behind the drywall and how far you want the "bump-out" box to stick out, etc.
My concern is that the 100-year old fireplace isn't going to be particularly happy about supporting the weight of the TV. Not so much the "dead weight" of the TV, but the additional stresses of moving the TV around will probably crumble and fracture the bricks and mortar over time.
  • Thanks for the reply, Gregory. The framing/chimney behind the drywall looks like this, as far as I can surmise: <img src="imgur.com/8yy1gjY" /> I agree re: fireplace mounting; I would not like to do any mounting to the fireplace itself. I'm wondering if I built a framing box that mounts to the studs on either side of it, if that would be sufficient to bear the weight of the TV and pulldown mount. Could you elaborate on the "short 2x4s perpendicular to the existing studs" idea? I'm having trouble picturing it. Thanks again! Dec 4, 2018 at 20:48
  • It depends on what's between the drywall and the chimney, the depth you want to come out from the existing drywall, etc. but this is kind of what I'm picturing: gyazo.com/793e2121ea376102d18cb239621b49ac (I apologize for the rough SketchUp.... not one of my strong skills) The short tie-in pieces could be a bit shorter, but I think some kind of arrangement like this would surely hold a TV.
    – gnicko
    Dec 4, 2018 at 21:37
  • Or, if you have the room, attach the "box" directly between the existing studs and do without the "tie-in" blocks entirely. That would be best, if possible.
    – gnicko
    Dec 4, 2018 at 21:43
  • Something like this would be best: gyazo.com/dfabcdf399ad149b8d2daa90f28cfbfe
    – gnicko
    Dec 4, 2018 at 21:54
  • Alas, the bump out is necessary, because the chimney is directly behind the drywall and inline with the studs on the left and right sides. In other words, the drywall lies flat against both the left/right studs and the chimney face--there's no pass through between the left stud and right stud. That first mock you sent is perfect--thank you! Your SketchUp skills go far beyond my own. Is there a name for this type of joining of studs? Would like to learn more about it and potential pitfalls if you know of one. Thanks again! Dec 4, 2018 at 22:29
It is up to you of course, but good solid masonry is great for fixings. I'd cut out a square of the existing drywall a bit larger than the base of the bracket and then replace it with a new piece of drywall (or tile cement backer board for even more strength) fully bedded in adhesive. I.e. instead of a small air gap behind the drywall go for full adhesive (like you would behind a ceramic wall tile for example). Fill the small seam between the new and old and allow a good amount of time to dry.
I'd also note down where the brick joints are when the drywall has been removed (so as to avoid them when drilling your fixing points.
The only caveat is that this plan fails if you open up the drywall and find poor rubble/ soft mortared/ old brickwork which is not very solid...
Update: Okay, if the bricks are a bit poor, you could still cut out a square of drywall and follow that with raking out the soft areas (joints mostly I'd assume) until the mortar feels solid (i.e. just scrape, don't take a hammer to it). Then mix up some render and plaster the area. Depending on the depth you'll need to do this in several layers over several days. If the mortar in the wall is lime based, I'd go with the same for the render (1 lime putty to 2.5 graded sand). Apply a couple of thin 'skimming' coats (fine sand and putty in equal measures) to the last 3-4mm 1/8th" or so to finish.
  • Thanks for the feedback, @handyman. One thing I should've added was that the house was built in 1910, and the condition of the brickwork/mortar is a bit of a concern as well. Dec 4, 2018 at 19:04
