I recently bought a house. In one of the closets, there is a small room with a bunch of wires, connections, etc.
I'm in the process of figuring out what exactly is going on to see if I can use any of it. Pictured here, I've got the most confusing bit: closet wires (I can take more pictures if needed)
  • Those small wires at the top get separated into 3 blue wires that leave together.
  • The small blue wire at the bottom connects to another Ethernet cable in another part of the room.
  • The two grey wires that go to the bottom of the screen is really just one wire (to long to include in the picture.
What's going on here?
Edit: More Photos
    looks like telephone landline connection ..... one line comes into the house and splits to all the phone jacks that are throughout the house
    – jsotola
    Dec 3, 2018 at 1:33
  • Oh, that sounds about right. Is there anything I can check to confirm this? Dec 3, 2018 at 1:36
  • Looks like there's a transparent phone jack in there. You might try plugging a phone into it. If the connector is too big for a phone, it's probably ethernet. Doorbell circuit too? Whoever did it was pretty sloppy. Should've at least have taped a note to the wall deciphering the tangle. Is the plastic enclosure by chance on an outside facing wall? what's on the other side? Dec 3, 2018 at 2:03
  • The transparent phone jack is part of the mess: The wire continues off the screen, and then it comes back in through the other grey wire. It is not on an outside-facing wall. The other side isn't accessible to me without tearing some (internal) walls. Most of the wires go up and away, though, not through the wall. Dec 3, 2018 at 2:08
  • What exactly are you asking, by the way? It might be hard to determine the exact function of those wires (since I've never seen communication wires spliced with a wire nut...), but they are nominally low-voltage, communication wires
    – Hari
    Dec 3, 2018 at 2:21
That's twisted pair communications cable. Could be used for phone or data and sometimes used (or misused) for other things.
More pictures would be helpful. Like the cables above the photo and some different angles. One thing that's confusing is those black stripes on that gray cable. Are those other wires within the cable or something else?
A pair is a colored cable with a white striped cable. Blue and white blue striped for example.
Telephones need one pair. A 4 pair cable can contain 4 telephone lines. Blue and white blue is typically line 1. Orange pair is line 2 then green and brown are lines 3 and 4 respectively. People don't always follow conventions though.
Older computer networks require 2 pairs. More recent networking requires 4 pairs. The mess of wires you have is more indicative of telephone (or something else) rather than data.
I see a blue pair that is connected to 3 or 4 other blue pairs by splitting the blue and blue white, bundling them and wire nutting them. I've never seen that done before. The single blue pair would be my best guess for the incoming main phone line.
You have some orange and brown pairs going to a keystone Jack which I have no idea why someone would do that from just this photo. If those orange and brown pairs come from that same cable that the blue pair came form it may be a second and third line. Home office and fax maybe. If from a different cable... Who knows. Can't really tell from picture. Maybe from cable modem for voice, maybe from VoIP adapter maybe something completely else. Hopefully not speaker wire since that's not the type of speaker wire you want to be running through your walls.
It would be helpful to know what Jack's you see upstairs and if the number of Jack's you find correspond to the number of wires in the photo.
There are better ways to distribute these types of cables.
The simplest is to use a phone distribution board. It has a 110 wiring block that you punch down the 4 pairs from your incoming cable and then additional blocks for each cable that runs to a wall Jack. On one of my websites I have an article on organizing home phone lines that shows more detail that you might find useful.
Phone wiring board
I eventually ran new cables and decided to use a 110 block, which is another wiring device. It's more complicated but also more flexible. Being more complicated made the project more enjoyable for me and for some reason I find it very satisfying to use a punch down tool I got to use a lot with the 110 block. I have an article on how to wire a 110 block.
How to wire a 110 block
A 66 block is another type of wiring device that is used for phones. It's an older style but still frequently preferred for phones.
How to wire a 66 block
My guess as to what's going on.
Since you provide more pictures and details this is what I think is going on. I left out the unused wires and only draw one line to represent a pair of wires for simplicity. Let me know if this diagram corresponds to what you see.
The three blue cables lead up to the phone jacks where you plug in your phones.
The grey wire is the incoming phone line from the telephone provider. It has the dial tone.
Line 1 is the blue pair and the main phone line used. All 3 blue cables have their blue pair tied to the incoming blue pair. There's also a grey flat cable with RJ11 connector connected to line 1 (I'll discuss this later) and another blue pair that runs down the left side of the photo and I can't see where that goes.
Also from the same grey cable (as far as I can tell) the green and brown pairs are punched down to the keystone jack. Then the green and brown pairs of the blue cable to the right are connected to this keystone with a modular plug. This might be a business line and fax line for a home office or something similar. The other end of the blue cable might be split off so that the blue pair goes to one jack and the green and brown go to another.
The reason for the flat cable RJ11 plug might be just to have a quick way to test the phone line at the source if there's a problem. It might also be that the person wanted to be able to have a way to quickly send line 1 to the jack that is fed by the green/black pairs in case they disconnected that phone service. All they would need to do is disconnect the green/brown wire plug from the keystone and insert the RJ11 that is connected to the blue wirenutted wires.
  • 66 blocks are less common in residential setups but are still quite common in commercial.
    – Machavity
    Dec 4, 2018 at 15:14
  • I took two more photos: I wasn't entirely sure what you meant by "black stripes", but I think you are referring to the tape on one of the wires. Dec 4, 2018 at 15:52
  • As far as # of Jacks, I've found 2 phone jacks upstairs. There may be 1 more (given that there are 3 blue wires going up), but it's not like there's a magic button I can press to find them all. Dec 4, 2018 at 15:55
  • @NathanMerrill I updated my answer with a diagram explaining what I think you have. Pretty sure it's phone. Can't see where one of the wires is going let me know if what I drew matches what you have. Dec 4, 2018 at 16:33
  • That looks pretty accurate. The other blue wire goes elsewhere and connects to another spliced wire. Thanks for the investigation :) Dec 4, 2018 at 16:38
Looks like your phone line. Is the line running into that j-box?
You can confirm that it's phone using a voltmeter: it will give you about 48 volts (DC).
Edit: whether this works will of course depend on whether the line is actually physically hooked up (which it very well may be, even if you don't subscribe to landline phone service). And whether it's hooked up is probably going to depend on your specific situation (is it a new house? was it recently built? do you know that the phone has been connected before? Or that is has never been connected?)
  • This is not a new house: It is 20 years old, and would be very surprised if a phone line was never used :). This looks like the right answer, but I'll leave it open in case additional answers come in. Dec 3, 2018 at 2:09
You have a RJ45 jack there with 4 wires. While it would be odd, it's possible it's an Ethernet data line (2 send, 2 receive, the remaining 4 are normally unused). It's also possible it's a phone line. If that clear jack is a smaller RJ11 that would confirm it, but I think that's an RJ45 plug. It could also simply be a way to connect two wires together. Look at the wires used in the jack. Pins 1,2,3 and 6 are what you need for Ethernet. If they're not all used, it's just a bridge of some sort.
The nutted blue wires look like a poor-man's attempt at distributing land-line phone. Normally the blue/white-blue wires are used for phone. That's not how you should do it, but it probably works well enough given the voltage incoming from the copper phone line. As Organic noted, a 66 punch board is the preferred way to do this.
