I'm replacing the pipe under the sink after it cracked.
I thought I had figured everything out, but the connector I got doesn't fit due to this non-threaded copper bit above the threads, is it something I can remove with pliers, or should I try to unscrew further down and replace it from there?
New pipe is 3/8" COMP to 1/2" FIP
under-sink pipe
connector of new pipe 3/8th COMP
That's a flared fitting (see: flared fitting copper). They are meant to accept the end of a piece of copper pipe, flared using a special tool. Looking at the picture, it does seem that you might be able to replace that part under the sink with a brass fitting (see: brass male-male pipe nipple ) that will properly accept your hose, but it might be difficult, given the corrosion.
