There's a few options of underlayment in local stores, fairly cheap and more expensive (based on cork, I guess). What are the differences, and what factors should I consider to make a choice? I'm planning to install laminate floor in a 2nd floor room, on the plywood subfloor.
Thanks!
closed as too broad by isherwood, Daniel Griscom, mmathis, ThreePhaseEel, Machavity Dec 4 '18 at 13:12
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • What's on the first floor directly below that area? – UnhandledExcepSean Nov 30 '18 at 18:19
The question is quite broad, but there are two primary differences (aside from cost): sound management and the ability to level imperfect subfloors.
Sound management (deadening, which can reduce tapping noise) depends on the thickness and composition of the underlayment. Leveling ability is primarily a matter of underlayment thickness.
You'll need to discuss the options as they pertain to your choice of flooring and your subfloor situation with your sales pro and make a decision based on your personal criteria.
