GFCI 20 amp breaker in main panel powers 1 bathroom on far end of house, 2 lights 1 fan on switches, and 2 GFCI receptacles.
Occasionally the power panel GFCI trips. I think the GFCIs are fighting each other.
I believe this is redundant and should not be wired this way because the GFCIs are causing the power panel to trip with nothing plugged in. Would it be proper to replace the Receptacles or the circuit breaker with non-GFCI?
I bought this house a couple years ago, older but remodeled some years ago. Every so often the power goes out only in the Master bath when nobody is in it, so far every time it shuts off it is because of the circuit breaker tripped and not a receptacle. When everything is working, when I trip the receptacle test button it only affects the one receptacle that was tested. When I trip the circuit breaker test button it affects the whole bathroom.
