I would like to replace this old iron cast fitting. See pictures. Do they make this type of fitting in PVC? Any ideas on which fitting i can use to replace it?
It looks like 45 degree wye with a side inlet. Fit a reducer and a 45 degree street elbow on the branch. enter image description here this part found here
    This won't be a drop-in, of course. You won't find a wye with threads on it like the cast-iron one you have now. That will require an additional part. I'd try removing the brass threaded piece and using a no-hub coupler to splice in a short length of PVC pipe.
    Commented Nov 23, 2018 at 14:18
