I'm trying to wire an outlet for my lathe. The manufacturer recommends a 15 amp breaker. I am planning to run 10 gauge wire approximately 25' to the outlet where I can plug in my lathe. The motor is rated at 8 amps. I currently have an empty 20 amp breaker for 220 in my box. Here are a few pics of what I'm thinking of using.
The first is the plug for the lathe:
The second is the motor specs of the lathe:
Would the following 20 amp outlet work for this?
I've wired 110 but never 220. Also BTW it has a phase converter allowing it to run off 1 phase.
