I've just moved into a new house and the heating doesn't work, hot water isn't circulating. I've narrowed it down to a stuck valve on the inflow to the water pump, it seems that the valve is closed. Unfortunately the thread on the valve has been worn down, so the usual tools can't attach to it (see pic).
Brute force with a spanner doesn't work, even after applying a lot of oil. I want to try gently heating it to see if that loosens things. Do any of you have some other tips or tricks that might help loosen it? I'm pretty good at home improvement but this one has me stumped...
