Found this in a box of tools and I have no idea what is called and its purpose, would someone let me know please.
There is a mark on it - T12399
  • Looks like a press or adjuster of some sort. It may have been part of a larger machine and wouldn't have a common name.
    Nov 19, 2018 at 22:04
  • well, i can't figure if have been a part of something bigger as there is no any screw holes or anything on it to be fixed, it looks like a part designed that way
    – Tony0001
    Nov 19, 2018 at 23:57
  • It does look like a tool used to press one part into another, such as a bearing race into its collar/cylinder, though I'm sure it has many other uses.
    – BillDOe
    Nov 20, 2018 at 0:04
  • Hello, and welcome to Stack Exchange. It looks like you've created a second account. Please Google "merge Stack Exchange accounts" and ask a moderator to merge yours, and then use one going forwards. Thanks. Nov 20, 2018 at 3:24
  • @DanielGriscom Moderators can't merge user accounts. If you see people with duplicate accounts, please direct them to the "contact" link at the bottom of the page to open a support ticket with SE; one of the options in the first entry field is "I need to merge user profiles".
    – Niall C.
    Nov 20, 2018 at 4:06
That is a fixture for repetitively cutting lengths of pipe or rod. The fixture is clamped to a workbench and the pipe is laid into the groove. The V-screw is then tightened to hold the rod. The end is then sawed off. The V-screw is loosened, the pipe/rod is advanced, then the process is repeated.
It looks like it's made to hold a rod or pipe. Maybe for drilling or cutting. Maybe it attaches to a drill press or saw.
