All 4 of my kitchen recessed lights quit working yesterday. I tried installing a switch but I have a black and white active nutted together.
I have two black wires one active one not and an active red. Copper is ground.
I can't figure out why they still don't work. The wires going into the light are black and white. Not getting a reading off of either of those. My understanding is to check the light closest to the switch.enter image description hereenter image description here
  • Hello, and welcome to Stack Exchange. Have you checked the fuse/breaker? Commented Nov 18, 2018 at 21:56
    How many wires were hooked to the old switch? Commented Nov 18, 2018 at 23:31
  • Looks like there is even a BLUE wire in that electrical box. Wonder what that is for.
    – Michael Karas
    Commented Nov 19, 2018 at 1:39
  • What is the general location? United States? Are the lights controlled from more than one location? Is that a new switch or what was there before? From what is visible in the photos, it suggests that there is another box in between the switch and lights. In a condo that could even be one of the counter plugs where it then goes to the cabinet lights. Most important question, what was done since the lights were last working as intended?
    – user68386
    Commented Nov 21, 2018 at 21:37
The power goes from hot (breaker) --> switch (wire should be black) --> [when switch is on] lights (wire usually red or another color).
Check voltage at the black wire at the switch. (Should read ~120AC between that wire and ground). If you're not getting voltage at the incoming switch wire (black), the problem is upstream to the switch. Did you check the breaker? (in your service panel, usually in basement, is one of your breakers tripped / showing red)? If the breaker is not tripped, then there's a break in the wire connection between the breaker and the light switch. Is it possible the switch is downstream from a GCFI outlet, which may be tripped? Check all your GCFI outlets...
The two white wires together are neutral. The black is hot (from breaker). The red is switched (to lights). The black and white together are probably switched or hot on another circuit, but they are not applicable to the light circuit in question.
