I'm looking to avoid using latex paint to paint my new OSB Wood. I know latex is easier to work with, but it seems far less durable when it comes to something that will see heavy use, like garage shelving.
The only type of oil based paint our local hardware store carries is Oil paint that's meant for metal.
Will that product work just fine for my 2x4's and OSB pieces?
It will work fine provided you don't apply it over latex products, which means you'll need an oil-based primer as well. (You probably do want to prime OSB.) It will also be more expensive than latex because your hardware store can only sell oil based by the quart. The solvents in it contribute to smog, vendors are required to verify that larger containers will be used on metal.
The limits on oil based have forced a lot of improvement in water based, oil isn't necessarily more durable across the board anymore. Specialty latexes for flooring are probably tougher than generic oil based. You can also find some one part epoxy paints that aren't too costly if you're willing to compromise on color. (They're mainly targeted for appliances and floors so the selection is limited.)
